It is currently Wed Aug 20, 2025 10:35 pm
PostPosted: Sat Dec 07, 2013 7:59 am
First name: Jeff
Last Name: Davis
City: Keystone Heights
Zip/Postal Code: 32656
ok, new to forum, have a potenial dumb question...... I've built two guitars, first two I just did reinforced necks, no adjustments, just a steel rod. On the third I ordered a Martin style truss rod that is 14 inches, but seems too short, it's suppose to be adjusable from soundhole, but then it's well short of the headstock, like the last 4 inches of my channel will be empty Is this ok? Or do I need to order a longer truss? Thanks for any input!! JD
PostPosted: Sat Dec 07, 2013 8:56 am
yes it is adjusted from the sound hole but the rod is only about 1/2 in from the neck block. you have about 3 in from the sound hole to the barrel nut on the rod
These users thanked the author bluescreek for the post: Jdsupertinter (Tue Dec 10, 2013 7:08 am)
PostPosted: Mon Dec 09, 2013 7:03 pm
First name: Jeff
Last Name: Davis
yep, that makes more sense, thanks!!
